nat0Z wrote:
P/coating only needs upto 200*C, ie our powdercoater only used 189*C.and they have a chrome powdercoat too, looks awesome but is pricey.
all you have to do is mask up where you DONT want the powdercoat, ie mask up where you dont want, poeder the lot, remove masking BEFORE baking as you dont want the masking tape adhesive to bake on!!!
no problems, anytime. (to save you the thanx! )nat0
Thanks nat0 (I had to say it ) - I will be going to precision powdercoating which is 15 minutes from my house (for Texas that's close) to see the superchrome and some other finishes from tiger drylac and spraylat. Hopefully I'll see something I like - most of the feedback I've read about it though states that chrome powder is a two coat system (it requires a powder clear as the 2nd coat for protection from oxidation, etc.) the clear dulls the shine of the chrome. But when I physically look at it I should be able to make a decision. From a cost perspective it can't be any more expensive than chrome or the black chrome for that matter (twice the cost of regular chrome) I'm doing, so anything I can do in powder will only bring the total cost down.
One drawback is that the powdercoating places here are very busy and are running 2-3 week turnaround instead of 1-1.5 weeks. That's almost as long as the chrome I'm having done, and they are polishing all the aluminum smooth prior to chrome which I would think takes significantly longer than the powder prep.
In any case I think I'll go take a look tomorrow and if I can pick up a 29-30mm socket to take the crank pulley off, may be able to drop off a batch so they can get started.
Thanks again for the info.
Nick.
