SilviaS14KA24DE wrote:NO! for springs go Megan Racing
Stiffer than tein stechs, and lower.
check this out
Megan Racing MR-LS-NS13 for S13Spring Rate - F : 6.3kg/mm Spring Rate - R : 4.46kg/mmRide Height - F : 1.75"Ride Height - R : 1.75"
Now Compare to these springs:
Eibach Pro-Kit for S13Spring Rate - F : 1.84~1.92kg/mmSpring Rate - R : 2.3~2.4kg/mmRide Height - F : -1.8" (eibach site) -1" (jnm240 test)read this. this is what he actually gotRide Height - R : -1.6" (eibach site) -.75" (test)
Eibach Sportline for S13Spring Rate - F : 1.92~2.0kg/mmSpring Rate - R : 2.4~2.5kg/mmRide Height - F : -2.2" / -1.75" (test)Ride Height - R : -2.1" / -1.75" (test)
Tein S-tech for S13Spring Rate - F: 3.7kg/mmSpring Rate - R: 3.2kg/mmRide Height - F: 1.5"Ride Height - R: 1.2"
RSR SUS Lowering Springs for s13Spring Rate - F: 3kg/mmSpring Rate - R: 3kg/mmRide Height - F: 1.6"Ride Height - R: 1.2"
Much better than those springs most people get
Ask Speed N Stylez about it. He lives in So. Cal and told a guy in florida $100 shipped. THats pretty damn far away, so if you live closer, the cheaper ya know? lol
Two things about Megan Racing Springs.
1 - Those are VERY stiff springs, and you'll rattle yourself out of your car, along with every bolt that doesn't have loc-tite on it. Also, you'll shorten the life of your shocks (even aftermarket shocks) substantially with something that heavy. KYB says that the AGX's will suffer shortened life span from anything stiffer than stock. You'll have to adjust the damping rate all the way up on the shocks just so they can try to keep up with the spring. Why anyone would want springs that stiff on a daily driver is beyond me.
2 - I don't trust Megan Racing. I own a strut tower bar made from them, and it's not the greatest quality.
And I lied, there are 3 points to my rant
3 - The megan racing spring rates are so radical from the fronts to the rears, that they'd promote understeering too much. The car wouldn't feel very neutral at the limit, and it will take some serious suspension tuning to overcome the understeer problems I can see occuring from those springs.
