Christmas goodies for the CA?
roast
Car: 1989 Silvia
Anyone buy/get some nice Christmas goodies for the CA?
I'll start and put the SDS EFI EM-3F as a christmas present for myself.
boost_boy
Indeed! I got another S13 with a CA that I built and an SDS system that I installed. It's actually a trade, but it's still a gift as it is a running car that I built and tuned for a good customer/friend.
NUTCSE
Car: 1987 Nissan Exa
CA18 build with a T61 = 300fwkw
I bought my CA a set of 1000cc injectors :chuckle: Just need some ARP main studs and ACL race bearings and its all of to the engine builder :bigthumb:
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
I got a Circuit Sports Magnetic Oil Drain Plug and a Circuit Sports BMC Heat shield :)
My fiancee is giving me $100 towards a car part of my choice also because she loves me sooooo much :D
I am, RIGHT NOW, ordering a Wideband and some other misc things for myself. Yay Christmas!!
float_6969
New alternator? Not really much of a gift, but it needed it. I miss driving my car. On the upside, I'll have a writeup on how to install an alternator from a '97 Nissan Quest when I finish installing it! LOL
sjbsuperman1425
CA18DET
that'll be a good gift for all of us!
float_6969
Gonna try and get the tensioner modified today, but we'll see how work goes. I've got dinner with some friends tonight, so we'll see how it goes.
roast
Car: 1989 Silvia
Dee, got any pictures of your new whip?
Nutcse, which injectors did you buy?
sbj, i had one of those drain plugs in my old coupe, neat little idea... (I ran a bone stock KA with advanced timing, so it caught next to nothing), you should consider a turbo blanket to manage engine bay temperatures as well...
float, :S sounds like you took the hard road on the alternator... can't you just get a shop to rebuild the stock CA alt?
float_6969
I could have had the stock on rebuilt, but it's a Mitsubishi based alternator and apparently those are REALLY hard to get parts for. It would have cost me nearly $200 to rebuild it and that's at a BIG discount. The Quest alternator was less than $160 w/tax.
The second reason is that I needed the increased amperage from the Quest alternator because I'm using an electric pump for the power steering/brake booster and it pulls as much as 60amps at full blast. I'm also planning on having a mild stereo setup in the car.
boost_boy
roast wrote:Dee, got any pictures of your new whip?
My computer has been jacked-up for quite some time, so I haven't used a camera in ages. The car had to be towed to my house because it wouldn't start, so after a few minutes of probing and testing, I had determined the coilpack base was bad. I changed it to a spare one I had and "Voila" . Only problem is that is $275 part from racetec, so uggghh! Anyone here know someone that's into data recovery? Most of my photos are in my bad hard drive that's been sitting in a box for quite some time.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
I ordered my:
Ksport Coilovers
Tein Tie Rods
Circuit Sports arm package
Megan Racing RLCA
Megan Racing FLCA
Tanabe Front Lower Brace
Nismo Power Brace
Circuit Sports front and rear sway bars
Tomei valve springs
Tomei Poncams
Stance alluminum subframe bushings
Stance slluminum differential bushings
SPL fender braces
AEM UEGO
Energy poly rack bushings
OE CA18DET oil pump
Sportmaxx 962's 18x9.5 gold
Pair Michelin Pilot Sport AS 275/40/18's
Pair Michelin Pilot Sport AS 245/40/18's
NUTCSE
roast wrote:Nutcse, which injectors did you buy?
I got the 1000cc Delphi injectors for quite cheap but i was really looking at the ID injectors.
boost_boy
Hey NUTCSE,
When are you going to put all of that stuff on your engine and in your car? It's been a while dude!
NUTCSE
Hey hey thats what happens when you get married and buy a house..........
In a month or so engine block will be sent to the machine shop, head is already done (4 port head, tomei 270/8.8 cams, tomei valve springs, porting), CPC FWD intake manifold, Masterpower T61 turbo.... should be interesting to see what it does on the dyno.
boost_boy
Be wary of that master power turbo. I hope the Aussie variants are better than the ones around here. They're okay, but I've seen them fail on the regular. What size back housing are you using with that puppy? Did you address your LSD issue or lack there-of? I do understand about the getting married and buying a home thing. I'm not married, but I've been with my children's mother for a very long time and I am a home owner, but that's not my problem. The problem is time and I don't have much of it; especially with all the car crap I got going on. I got too many cars and only one me to either maintain, build or enhance them. But just know that you are not alone :ohnoes2
DALAZ_68
Car: 90' 240sx CA18det
bought the following
Rod Bolts
Rod Bearings
Headgasket
Piston Rings
oil pan gasket
head bolts
and other crap that added up to roughly 700 or so... :cry:
