Chris you got any of the tech talks?
NISTECH
Hey bud I need to reffrence the march 97 tech talk, I have all of 97 except march and april. Have every month of the year before and after. I am looking for a listing in it on the J30 maxima with the VE in it. It has a wiring diagram to correct a problem with the power transistor.
s13sr20chris
i will check first thing on tuesday bro.
NISTECH
I appreciate it.
s13sr20chris
sorry bro. went through mine and the other two team leaders stacks. none of us had that particular issue. if you want tech bulletins from 1976 we have that and other useless stuff but no march 97.
NISTECH
Yea we have all the old TSB books too, this dealer I am at used to be in another part of town , pretty much since dirt was dirt. There are only 2 guys left from the original store and none of them had them either. I am going to have to let that part of the job slide, I didnt sell him or recommend the rewire any how. As it turns out just replacing the coils on the VE fixed it. If you ever come across an old J30 VE with a problem where a customer complains of occasional dieing and total power loss under hard accel intermittenly. When you are driving it and watching consult , under hard accel when the car gets over 4k RPM it intermittenly cuts total power , like you grabbed the ignition and turned the car off, your consult screen goes to "wait" but when you let off the throttle it comes back to life and you can accelerate again and may not have it cut out this time. IF you hold the throttle to the floor and let the car coast down to around 25 mph the surging you see the tack do will start being felt as the car will accel then drop then accel in split second intervals, but again when you let off the throttle it will come back to life and off you go. Honestly strangest thing I have ever seen. I checked everything from TPS, to MAF , to ECCS[EFI] relay. Checked grounds load tested circuits, Then I disconnected coils one at a time till it didnt cut out in numerous accels. Finally traced it to #5 coil. Then went to asist for the second time and was able to find a tip refferring to rewiring the Power transistor with a diag out of that issue.
