pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Tue Jul 22, 2003 3:46 am
Ok I have about 3 problems that are all probably related. I have a 1990 240 that when I start it up in the A.M. it cranks right up and idles perfect, but when I go to take off the engine falls flat on its face. Once I have driven the car until it warms up it drives fine. Then once the car is at operating temp the idle sits at about 700 rpm but its pretty choppy. And when I am accelerating I have a surge under light load and it goes away under heavy loads. Over the past few thousand miles I have replaced the following parts for various reasons. TPS, Temp sensor, o2 sensor, plugs, wires, cap, rotor,fuel filter, and removed AIV. All of these things have improved the performance, especially removing the AIV, but it still isnt just right. The choppy idle is a newer problem and doesnt seem to correspond with any work that I have performed. Anyways, any advice would be greatly appreciated.
Thanks,Phil
