choppy acceleration = bad speed sensor?
jsomogyi
Car: 97 240sx on Eibach pros with Koni adjustable shocks
My acceleration is choppy sometimes, especially under heavy accel. The check engine light came on one day after hard acceleration , and the problem has persisted ever since. The mechanic gave me the following codes . Being firestone though, they couldnt really tell me much about the problem.
code 28 overheat
14 speed sensor
31 electronic controle module
21 - ignition coil
. Do you think that just replacing the speed sensor should do the trick? What do you think is happening? Note, the car has 230k miles.
240dx
Car: '97 Nissan 240SX LE
the speed sensor shouldnt have anything to do with it.
my guess is take a look at your ignition coil. sounds like it may be misfiring.
also whens the last time you did a basic tune up?
jsomogyi
240dx wrote:the speed sensor shouldnt have anything to do with it.
Im not sure . Thanks for your help.
Space Monkey
Car: 1990 Nissan 240sx
I think he he right. The speed sensor is for your speedometer only i think.
Check you spark plugs, distributor, ignition and injectors.
poshatch
Car: p.o.s. 1990 240sx hatch
my friends s14 is doing this at the moment too i think...its like perfect up until 2.25 or 2.5 rpm and then it starts shaking violently like the whole car like its accelerating and decelerating like every half a second, im not sure what it could be i thought it could be his knock sensor malfunctioning since it seems rpm and ignition related..is this the issue your having?
Gabes13
Car: rb20det s13
jsomogyi wrote: 31 electronic controle module
Is that the ecu?
Kinda ironic that it would throw a code for itself.
You should check that out.
