"Chirp" when locking with door handle request switch
daltonvol
Car: 2014 Rogue SL (Premium Pkg)
Traded - 2013 Rogue SV (SL Package)
2011 Maxima S
My mother-in-law has a 2014 Rogue SV, and I have the 2014 Rogue SL. I've had to drive hers a few times, and I've noticed when I lock hers with the door handle request switch, it "chirps" (not horn honks) when I lock it. Mine, however, doesn't do this. I've toggled the "Answer back horn" option in the vehicle information display, but all this does is activate/deactivate the "horn honk" when I lock with the intelligent key.
Also, I do hear the alert "chirping" when I exit the car while it is still running and/or try to lock using the request switch while the keyfob is still in the vehicle, so I don't think that the fuse for the "chirp" is bad.
Any advice? Thanks!
ezb57e
That may be a BCM setting the dealer can change.
AnthemGems
Car: 2014 Nissan Rogue SL Gun Metal Charcoal Interior
Check page 3-15 in the owners manual
daltonvol
2011 Maxima S
As far as I can tell, there's nothing on 3-15 that addresses my question. What did you see there that you thought would address my issue?
Return to “Rogue Forum”
