Chirp in third gear?
sohc90adel
Car: 1990 Nissan 240sx HB 5 speed Grey
Hell Yeah! I just finished installing the ACT street disk and HD pressure plate with my dad in my 1990 240sx HB. Man what a great upgrade, thanks to all of you guys for talking about it so much I did the install. Well the realease bearing was all jacked up, and that the reason for the install but im still in shock on how well the car is perforiming now. It should be one of the first things to do. never thought 140 horses could chirp in third so easy. Thanks a lot and that my sharing for today!
sixxdeuce
Car: 93 rx7, G35coupe 6mt
What kind of tires do you have?
Cyberkreig
Car: 1993 Nissan 240SX SR
You did give the clutch 500miles of gentle driving so it could properly seat/breakin right?
sohc90adel
no 500 miles (does not say to do that in the instructions). and i got regular crappy michelins on the rear 205 60 15. I need posi now, i got the differential im just waiting for the new bearings and seals from courtesy nissan.
quiksilvia
Car: 95 s14 se
its not in directions, its a well known fact by EVERYONE that when u do a major mod or replace something important, it has to settle in first, start saving now for a new clutch
sohc90adel
thats the funniest thing i ever heard, im not racing my 240 i did nothing but take my car out for a spin, i just got the clutch man, its gonna last me a long time, but ill let you know if anything goes wrong but i doubt it, ACT is a good quality clutch. Highly recommended!
Nismo1182
Car: Z06
its true though, you should let it settle in before chirping gears, etc.
miteymax86
Car: 86 Nissan Maxima
Gots a 240 now
ACT's I seem to remember from some DSM shopping I was doing, are highly sensitive to proper break-in, I'd take it easy as you don't want to risk grenading a spring through your hood
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
A friend (honda guy) doesn't think a clutch needs time to break it either. I keep telling him its best for the clutch to be driven easy for the first 500 miles, but NOOOOO. i can't wait till he needs a new clutch in a few thousand miles (if he ever gets his POS crx running. heheh)
sethable
now what you did prolly will not be too bad for the clutch, and I can understand why you went out and tested it out nothing wrong with that but take it easy for the next while with that thing and work it in nice like.
sixxdeuce
Sounds like you wernt too hard on it so far but just drive like a grandma for a few hundred miles, it will be worth it in the long run. Kinda like new brakes, you gotta let them break in you dont go balls out on a twisty downhill after you change them.
Good240
Car: Cars, Music, Movies
My ACT clutch is only 1 week old and I've done a little here and there but not anything extreme like burnouts that span multiple gears or power shifting... just quick shifting. Being that I mostly drive it like grandma and a mostly stock 240SX I feel it'll be ok. Redline launches must be kept to a minimum.... 500 miles pass before you know it anyways.
UncleBen
My ACT Street is on backorder. It's pissing me off. I'm getting it for 307 shipped though. heh
sohc90adel
Yeah i have not done anything drastic, the thing was after me and my dad installed the clutch we turned on the car to move it out the way so we could clean up the floor, the thing was i thought since it was a street clutch it would be kind of the same feel. Boy was i wrong. i actually peeled out a little when i went to take off by accident( i said to myself i gotta check this out). So i went and took a test spin no redlining just quickshifts nothing major, but i did hear a chirp in third,very happy with that! so yeah i work 45 miles away from my house so the 200-300miles will be out of the way pretty quick. I got the Clutch from MVP and they had it the cheapest and had very good people working there i had no problem what so ever. 282 bucks plus shipping.
ITA240SX
Car: 240SX
LMAO at some of these replies...
FYI, this is from the ACT website:
"For organic street discs “00 and SS” we recommend breaking in the clutch for 200-300 miles with mild engagement such as stop and go city driving prior to racing or spirited driving. ACT race discs usually only require a few hard slips to lap in the surfaces prior to normal driving or racing. Do not overheat the clutch during the break in period."
Adel - don't sweat it, you'd have to work really hard to tear up your new clutch with these little pea-shooter engines we run. At worst you'll loose a few thousand miles of use from not breaking it in. One question though, did you have the flywheel resurfaced? I noticed none of the replies here mentioned this, but a warped, cracked, or just glazed flywheel can cost you a lot more than improper break-in.
Earl
574-240sx
Car: Nissans, Toyotas, Subaru
i shattered a cheapo clutch disc in less than 1000 miles. Nick
TomsMR2
Car: cars.. etc
if you can even chirp first...
.. you need bigger tires
sohc90adel
Earl,
the flywheel was in good condition when we changed then clutch, actually the clutch was in good condition the only thing that went bad was the realease bearing which was making a hell of a lot of noise.
The only reason "I think that i am chirping in first through third gear is because of my open differential. I just pressed new bearings on to my posi that i bought off ebay, so soon more traction!
On 240sx with HICAS, What is the posi rear end called? Is this Posi any good? Yes this is the one i got.
240SXer
Car: 1995 240sx SE (2jz powered)
I have 225s in the rear, and I could chirp 3rd on my stock KA. But with the bald 205s I used to have, I could spin 2nd really hard.. Torque is a lovely thing :)
TomsMR2
Car: cars.. etc
you spin 3rd with a vlsd, and 225s? hmm..
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
I broke my spec stage 3 in for about 400 miles. then i went and autocrossed it. :batman
240SXer
I don't have VLSD... So i'm chirping 3rd with an open dif and 225s. I've got a ACT street disk.
240SXer
I'm talking about my 95, not my 91. My 91 has VLSD but something is wrong with the motor, it's not pushing nearly as much power as it should be.
sohc90adel
im getting lsd soon. do you guys think its a good idea to get wider tires? Give me some pros and cons.
240SXer
Pro: better traction, looks better, better handling
Con: clearance issues, more weight
sohc90adel
clearance issues? 225 dont fit? i doubt that. Itcant be that much weight can it?
240SXer
As you can see there aren't too many disadvantages, but the weight IS one, probably a pound or two but more weight is more weight. 225s fit on my S14, but they ARE wider, if you go much larger it might rub the fender, especailly if it's lowered. Just check the clearence before you buy some tires you can use. You have 15in rims so you're in a totally different ballpark. Just gotta research what'll fit a bit. I think I could have fit 245s, which pisses me off. But I guess i'll have to wait till i mess these up.
sohc90adel
how about speedometer issues? will that mess up?
240SXer
Yup... Bigger diameter will make it read slower, smaller will make it faster. You can often however, get wider tires without them being much taller.
Ex. 225/45R/16 my new size, 205/55/16 old..
Do you know how tire sizing works?
225 is the width, 45 is the height, but it's 45% of the width.
So the height on 225/45 would be 101mmHeight for 205/55 would be 112.75
So my new tires are smaller making it read faster. If I would have gotten 225/50 it would be 112.5 almost the same, but they don't make EVERY combonation espectilly in brands that are good. So you just have to research it.
