jagr200 wrote:If I were to install a Injen or some other manufactures Short Ram Intake on my 2006 Nissan Altima 2.5S 4CYL do I need to chip my car so it will run good with it? I have been told by a friend that I do. So Im not sure. Have you guys chipped your cars to install a Short Ram Intake? Thanks
First off. There is no chip for the new style Nissan ECU.
A proper dyno tune will generally net you more gain dollar for dollar than anything else outside of a huge shot of nitrous. It's also safer and good for better economy at the same time. Tuning is about efficiency, a side effect of having your motor run more efficiently is that you will create more power. Also while tuning they can make sure your car has stable and safe AFR and Timing if nothing else, so you should have a more reliable vehicle in the long run.
If you add modifications to the car without a tune, you will not get the most out of those mods on newer vehicles because the stock ECU doesn't know how to adjust itself for modification, all if can do is try to fall in line with the parameters it was set with by the factory. Often times in trying to do so it will make your car run rich or lean and both have their bad side effects.
This was not the case in previous cars because they didn't have intelligent ECUs, you could just chip them with a generic tune and they would work better. The stock "tune" was rudimentary and served it's purpose but it wouldn't adjust much of anything based on sensor input. Newer intelligent ECUs don't have static information, the "tune" is based on thousands of points of logic and often is totally regulated by sensor input. Change the way a sensor reads and you render the entire system ineffective.
You do a proper tune (each individual vehicle is different) and you'll allow for better economy, more power, and better reliability. A hand held flash programmer isn't much more than what the old "chip" was, a base tune, usually rather generic based on a car that probably doesn't run the same as yours nor does it have similar modifications.
