jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Fri Aug 25, 2006 8:10 pm
in time however, the chipped ECU would need to be reprogrammed again to control MAF, ignition, injectors, etc. running the engine under mad boost will result in lean misfires and if you are pouring in too much gas, rich condition.
HKS F-CON man.
and if you need SRs, i can get you through a shop in brisbane. hit me up.
