Ok so I reset the safc and input what I thought to be right but the car would not start.So I started thinking that it was my tune so I put the old chip back in and it started but it ran like crap,it would not idle above 500 rpm and if I gave it just a little gas and then let go of it it would stall.So I guess maybe the safc had been set to a specific tune for that rom.If somebody would be willing to look over these files and settings for me and see if there is something I can do just so I can get it to the tune shop(about 45 min away)and get it properly tuned that would be great.It is of course a CA18DET with a z32 maf and 450cc injectors.The ecu is MEC-D017 p/n 23710 36F15.I used the stock rom for that ecu and just adjusted for the maf and injectors using live edit for my tune.For the settings on the safc I set the sensor for hot wire then "in 2 out 6",set it for four cylinder and ** for the throttle signal and that was it.
Here is the rom file for the tune that I did
http://www.mediafire.com/?9j05jbfsms1
And here is the original that was in the ecu
http://www.mediafire.com/?bzemgnrq19j
And if your wondering why I even messed with the ecu if it was running before,it's because when I got around 5500 rpm it felt like it hit a rev limiter or something it would not go any higher.So I assumed it may have something to do with the tune,and when I compared the stock rom file for the ecu it was totally different from the rom that was in the ecu when I got the car so thats why I did it.
