CHIP??
speedjunkie
Car: 91 300zx TT
ive beeen tring to find a good chip and the best one i have found so far is
Venom 400 Performance chip i was wondering if this one was allright and if n e one else had suggestions thnks
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
the venom "chip" is garbage.
the only ecu programs I would run are JWT or Z1....and the Z1 program is nearly identical to the JWT, just a little more aggressive, and its less than half the price
Logan76
Car: Junk
If you bought a Venom 400, you just thrown perfectly good money down the drain, instead of buying that 300$ "chip" spend a few hundred more and do a shot of nitrous if you want cheap HP, assuming your not driving a turbo z, then your options are limitless.
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
Logan76 wrote:If you bought a Venom 400, you just thrown perfectly good money down the drain, instead of buying that 300$ "chip" spend a few hundred more and do a shot of nitrous if you want cheap HP, assuming your not driving a turbo z, then your options are limitless.
Don't listen to the just throwing a shot of nitrous at the car. The ECU upgrade is an essential early step in modding Z32's.
He has a TT btw Logan
Logan76
Car: Junk
Then I am teh stoopid
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
Logan76 wrote:Then I am teh stoopid
No not at all Just letting him know which route is the best.
Zinister
Car: 1991 Nissan 300ZX Twin Turbo and 1990 Nissan 300ZX N/A
speedjunkie wrote:ive beeen tring to find a good chip and the best one i have found so far is
Go with the Z1 ECU. I purchased and installed mine about 1-1/2 to 2 months ago and I love it! Its cheaper and easy to install, as it is a plug and play ECU. It also comes with the boostjets. Good luck!Here http://www.z1motorsports.com/p..._id=5
Ill give u a head start
Car: 1993 Nissan 300zx Twin Turbo
are there any upgrades needed before installing ecu chip?
Zinister
Ill give u a head start wrote:are there any upgrades needed before installing ecu chip?
Usually the BPU stuff. I had intake and Turbo back exhaust and my crank pully when I did added the ECU. The good thing is they build it to you Z's specs and you can always have them re do it when you add more mods. I.E. Injectors, Dual intake, Intercoolers, etc...
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
I'd recommend doing intake, exhaust, and testpipes around the same time as the ecu/boost jets. Those four things will give you quite a healthy jump in HP versus stock (about 100hp).
Also, instead of the boost jets that come with the ECU, look into a quality electronic boost controller. Just don't turn the boost up too high
