NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon Jun 20, 2005 4:15 pm
Expensive is a relative term. This depends on your personal income on weather something is expensive or not. Typically in terms of car repair its not all that expensive as compared to say a valve job or even a major service. The labor costs vary across the US But I wil give you an approximate labor time for the job, they will get you for anywhere from an hour to an hour and a half to remove and replace it. The dealer I work for charges $98 and hour, but I am in a higher cost of living state. the rate in knoxville will likely be cheaper. The cyl itself will be somewhere around $60 very rough guess.
