ayjay »
https://forums.nicoclub.com/ayjay-u5495.html
Thu May 12, 2005 1:32 pm
i live in vancouver, bc and the testing here is as harsh as california emissions. these are some of the things we do to pass:
-get some Methyl-hydrate and pour a bottle of it into your tank, along with the highest grade fuel you can get... between 94 octane and the methyl-hydrate you'll be runnin super hot and real clean.
-another good thing to do is take your car for a really spirited drive before getting the testing, get the engine as hot as possible cause it'll run cleaner as well.
-and as for the 18" rims, that's not necessarily the factor it's the profile of the tires that matters... if you're runnin 35 profile tires they won't put you on the rollers cause they'll damage the rims otherwise, you might be able to fight it with 40's
-and loosening the bolts a little (between cat and dp) is a good trick, as long as it's not too obvious that there's a huge frickin gap in your exhaust
