Postby
GseaQ »
https://forums.nicoclub.com/gseaq-u329.htmlSat Feb 16, 2008 9:53 pm
Hot would be best as that's the way it will operate. However, the dipstick has a "HOT" mark on one side and a "COLD" mark on the other. If you were doing a drain and fill at home, for example, you could fill and check by the cold mark and fine tune more accurately by the hot mark.
Postby
goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.htmlSun Feb 17, 2008 4:56 am
In the old days the transmission had to be in DRIVE to check the fluid. Do you check the Q's transmission after a 10 minute drive while in PARK or DRIVE? Should the fluid settle for a minute or two first (like the engine oil) or do you check it immediately after the drive? I'm always a little confused on this one.
Postby
Haitian_King »
https://forums.nicoclub.com/haitian-king-u54261.htmlSun Feb 17, 2008 5:47 am
I usually check mine (out of paranoia) as soon as I pull inot the driveway after my 23 mile drive from my school to my house. I'll be doing 80MPH the whole time on the turnpike and about 45-65 until I get home. (Unles it's right after school and the crossing guards are out.)
My dad always told me to check it hot. I never knew about having it in different gears. I always checked it in Park. It'd be difficult for me to check it in drive. Who would stop the car from moving?
I thought engine oil was the only thing that could could be checked cold.
