Peabody wrote:H E L L O
Anybody have the answer?
Is it the same as the DE to check & adjust?
Thanks
I just saw your post, i have an 89 auto hatchback. You will find the adjustment screw at the base of the air intake on the passenger side at the rear. It's not buried like the 91s. On the front of the air intake is the tps just to the side of the throttle body where the butterfly is. Just below that is the connector. Warm up the engine, park it, turn off and disconnect the tps. restart the engine, turn screw clockwise to lower, counter clockwise to raise. when you hit 650 rpms turn off engine, reconnect tps and thats it. I just did this today and my car is at 700 rpm in park. Hope this helps.
