Checking timing w/ timing light... Issue
Schrute Farms
Car: 93 Datsun 240sx
Car is a 93 240SX 5spd conversion from auto. All emissions removed (PAIR valve, EGR, etc.)
I am going to check my dizzy timing. Here is my issue: when the TPS is disconnected, my idle is at 1300 RPM and the idle screw is threaded FULLY in... I just cleaned the idle air valve a few weeks ago. When the TPS is plugged in the car idles fine (~700). Will I be okay to go ahead and play with the timing even with the idle this high?
Modified by Schrute Farms at 11:17 AM 2/13/2009
Schmitz_7
Car: 1990 Subaru Legacy Wagon Touring Edition, Mitsu Elclipse 2003 GS, 240SX Nissan 1990, 2001 Hyundai El
<---- = IDK.
Sorry man but that baffles me. timing has never been an issue to me. Only electrical and such. Lemme do some digging for you.
Schmitz_7
http://overlandtrucks.com/kaiser/tech/timing.pdf
hope that helps.
Read up on it.
I searched for a week for an answer to my question before i even posted.
Schrute Farms
I should have been more clear.
Everything is in working order. I checked/tested/cleaned/replaced the following- coolant temp sensor, mass air flow sensor, oxygen sensor, spark plugs, spark plug wires, fuel pump, fuel injectors, fuel filter, air filter, distributor, pulled trouble codes (found none) and ignition coil, IACV.
My idle is still at 1300 with the TPS disconnected and Idle screw set all the way in... Yet with the TPS plugged in it is dead on (700 RPM +/-50)
My question was- will I be okay to set the timing anyways even with the idle that high? I feel like I am out of options because I've tested damn near everything idle related... I should have reread my question before I posted in the original post. Sorry!!! Edited!
Cone Junky
Car: S13 fastback
BMW e46 328i
The first thing I would do is find out why the idle is so high. You either have an intake leak or the throttle body isn't adjusted properly. The timing adjustment would not be accurate at that high of an idle.
