Checking the Transmission Fluid
05_G35grl
Car: 2005 G35 coupe
Hi there...new to the site. Great info on here! Love it!!
I recently noticed when I shift my AT into reverse, there this awful noise, that I don't think I used to hear when I shifted into reverse. I'll have to listen to see if it happens when I shift from reverse to drive. I've been searching the internet for info on how to check the fluid level. (I had a Honda Prelude before & worked on it myself, so I'm somewhat familiar with looking under the hood) Any help would be great!!! Thanks!!!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
WELCOME to NICO!
Checking the trans fluid is really easy... You need to check it hot to get an accurate reading.... I assume you know where the dipstick is so I wont insult your intelligence.... ITs just like checking the oil, except you need to check it when the engine is RUNNING in park...
joe603
Car: 2014 Durango R/T
What about checking the level for a manual?
elwesso
2007 BMW M Coupe
you cant really check the level for the manual (no dipstick)... Technically you're supposed to just refill the trans fluid and fill until it comes out of the fill hole... So if you wanted you could take the plug off the fill hole and make sure the level is up to that level.
05_G35grl
Car: 2005 G35 coupe
Thanks! It took a little while to find. Nissan sure doesn't make it easy to work on this car. I can't believe they have the trans fluid dip stick bolted!!?? Is there a seperate fill hole?? I didn't see one...
Sorry to sound like such a chick, but working on the Prelude was much easier. I'll be going to the Nissan dealer to get some trans fluid now...
C-Kwik
Welcome to NICO! Needs to see some pics of the car!
I'd guess it's bolted in so people don't do stupid things with the car. Was the fluid low after all?
05_G35grl
Car: 2005 G35 coupe
Yep...checked it with the engine running, and just the bottom tip of the dip stick had any fluid on it...
Haven't done any upgrade or mods to the car. It's a stock '05 lakeshore slate coupe.
elwesso
2007 BMW M Coupe
youll put the fluid in the dipstick hole.....
infinititech1
yeah they are bolted down...10mm....and some of them dont even come with a dipstick althought it looks like one. but you are probably about half a court low. you need matic J fluid ONLY!!! anything else will damage the transmission! and yes fill it through the dipstick hole. make sure the transmission is a little warm and car is running in park.
05_G35grl
Car: 2005 G35 coupe
Hey infinititech1, thanks for the info...
Nice bike...R1 or R6?I gotta 2002 CBRF4i...but I suppose this would belong on a different message board/forum.
infinititech1
its an r6... just hit me up on aim so we don't get in trouble on here
lifeon1wheelr6
infinititech1
and...can i have your bike???
05_G35grl
Car: 2005 G35 coupe
no way man, what are ya thinkin? you have ur R6
car sounds better now that i added the ATF...the fluid level is at the 1/2 way mark of where the cross-hatches are on the dip stick. didn't want to overfill the thing...
infinititech1
but that f4i's make good stunt bikes...can i borrow it??
Road Ruler
Car: G35 sedan prem
My o3 has the bolted down cap but " NO DIPSTICK" Can I order a dipstick? If so anyone got a part number?
infinititech1
ya sucks that infiniti did that with some of the g35's. stupid if u asked me. umm i can look tomorrow if u need
Road Ruler
Car: G35 sedan prem
Yes I would like a Part Number for the Auto transmission dip stick.
I asked the local Infinity dealer for one and the reply was "Just bring the car in here and we will check it for ya"
Hummmmm, if I wanted to drive 40 minutes for Infinity to check it then why did I bother asking them for a dip stick!!! Frustrated, I just walked. At least at this site we get a litle TLC with our problems and concerns.
3 cheers for this forum and the assistance we get.
infinititech1
i don't work til saturday...but i'll try and remember to get it for ya...
