250, 000km, which is around 160, 000miles?
Fuel Pumps needs to be replaced, and something with the clutch linkage is broken. It runs.
He said he swapped the engine out for a KA20DE. How do I check this out? I heard there are numbers on the firewall, but are they underhood by the drivers side? Since the engine has been swapped or not, the numbers ****.
I only saw the car drive by a few times. There is sunroof, body is decent, and I didn't see any rust yet. It's a 5-speed as well. I don't how to drive 5-speed, but I'll learn.
Here are my questions:
1. How do I verify if it's a DOHC, and not a SOHC?2. Where is the number on the firewall? What do these numbers mean? I should see S13 in the number right?3. I will be checking out the tires, rust between doors, and the trunk, the brake lines, the overall cleanliness of the interior, and other easy visuals. What other things should I look for?4. If it turns out to be a SOHC, can this engine produce decent power?5. What are the cosmestic changes from the 89 to early 90's 240SX?
Note: He's asking $1000CDN($650US?), and I'll probably pick it up for $800CDN($500US?)
PS. I know it's long, and there's lots of questions, but that's why I numbered them.
Thanks, for all the help.
