Checking oil...
CPs G35 2003
Car: 2003 Infiniti G35 Sedan - Desert Platinum - no mods
I've seen quite a few posts about oil consumption. Here's one about checking oil.
I actually feel pretty dumb even asking this, but has anyone had trouble reading the dipstick on their 2003 G35. I've been doing this (checking and changing my oil) ever since I could drive (@ 20 years), but the dip on my G seems to come out pretty sloppy, which makes it difficult to get an accurate read. I've been trying to keep an eye on it due to the typical G consumption issue. Need some solid advice.
Thanks, CP
ginag
Car: g35
I think you have a great question! I feel the same way I have a 03 it seems like a guessing game. Look forward to seeing if anyone has some advice.
infinititech1
what i usually did is just pull out the top part a little bit then slowly work the rest of it out
Jons_G35_sdn
Car: 2003 G35 sedan-no doggy door,91 240sx sold,04 subaru wrx stage 2
i could not agree with you more, there is no way you can get an accurate read. That stick is some freaking flimsy, putting it back in sucks too.
maybe i should put some lube on the stick, some engine oil or something
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Location is bad.I assume you guys are looking at both sides of the dipstick???Sometimes it takes me a couple tries to get a good reading too.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Yep, location is bad, terrible if you have a pop charger. It never gives a decent reading. I just try again and again, and eventually get a decent reading.
telcoman
CPs G35 2003 wrote:I've seen quite a few posts about oil consumption. Here's one about checking oil.
Thanks, CP
I'm not familar with the 03's but on my 06 I try to check my oil after the car has been in the garage all night. If you check during the day, let the vehicle sit for 15 to 20 minutes after use. The oil in the dip stick hole will drain allowing you to get an accurate reading. If you add a 1/2 qt or so, you'll have to wait again because some of the oil you just added is in the dip stick tube and it takes another 15- 20 minutes for the oil to drain out of the tube. Its a real pain in the *** but after over 47k miles I have a pretty good idea of how much oil to add from reading the dip stick.
Telcoman
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
^+1
I can't wait till I get my new GT-R! The stick is on the front out in the open...and looks super easy to access!
....oh wait! I'm poor damn it! I guess I'll have to stick with the flimsy/floppy/poorly designed G35 stick...
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
its on the front on the 07 sedan and the 08 coupe too,
Its the yellow loop between the engine and the radiator in the picture below.
g35beauty03
Car: 03 g35 coupe
I have an 03 coupe and I havent really had any problems reading it.. But it is really weird shaped and a pain to put back in in the dark lol.
Thanks, CP
IlsG35
Car: 2003 graphite 6speed G35
i took a cutters to my dip stick n the re welded the dipstick so its not that long n i get a good reading all the time now cuz i dont have to struggle to get it out.. but on ALLDATA it say it takes 4.5 quarts of oil n its right give or take a lil bit...
