checking main clearance
wild_maxx
Car: 90 TT pearl yellow z32
when installing my main bearings with stock main bolts i checked the main bearing clearance and came up with .0015" (1 1/2 thousandths)
When i was doing the final torque on the main bolts one of them snapped.... so i removed the broken bolt and decided to get a set of arp main studs.
Question is... should i re-check main bearing clearance's again or should it be the same when switching to the arp hardware?
KATwo40
Car: 1993 240sx KA-T
Should be the same, but checking again is free.
Florida240sx
Check it again.Because if you spin a bearing in a couple weeks you'll be kickign yourself in the a$$. If you have to ask yourself if you should do something, then you should do it.
