Thee 240sx Owner »
https://forums.nicoclub.com/thee-240sx-owner-u6269.html
Sat Jul 10, 2004 3:38 am
have you changed your fuel filter.. thats the cheapest and easiest way to find out... you also didn't mention if you checked your injectors or not.. you have 4 things it could be.. your fuel pump is bad or strainer is clogged, your fuel filter is dirty and needs tobe changed, your injectors are bad and need to be heat treated or replaced, your FPR=Fuel pressure Regulator is bad and needs to be replaced. and as well.. your sensors could be bad that control your mixture which is in this order, MAFS, Air Ambient Temp Sensor, Collant Temp Sensor, O2 Sensor. they all control mixture so if theres a problem with one of them, it will throw your mixture either lean or rich which will cause your power loss. but if you did that all... you should replace your fuel filter.
