Checking CVT Fluid
General discussion area for the L33-chassis Altima.
mvftw
Car: 1996 240SX SE
I bought an aftermarket dipstick, so I'm not sure it correct. Does anybody have the size and where the marks should be? Also Should it be checked warmed up and idling or warmed up and off?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
transmission fluid is always checked warm and running. Aftermarket sticks are not reliable, you need to calibrate it by doing a fluid change using the leveling plug.
Return to “5th Generation Altima Sedan (2013-2018)”
