checking codes on rb25 s2
lilskyline240
Car: 90 240sx w/ rb30det
how do you go about checking the codes on the rb25 s2? there are no lights to look at? do you need a diagnostic tester?
lilskyline240
anyone?
lilskyline240
no one knows how?
Bluefire
Hook up the CEL wire. Then short the CHK and IGN ecu pins for 2 seconds and release. The CEL will now blink the code
-Bluefire
lilskyline240
my CEL is hooked up. how do you go about shorting the CEL and IGN?
wawazat8402
Car: 89 Sil80- RB25DET
I think you just use a jumper wire. I just wired in the Consult plug and ordered the cable and software from PLMS. It made my life a lot easier when I was troubleshooting cars I was working on.
lilskyline240
what does the consult plug look like?
wawazat8402
Stock it is by the fusebox behind the drivers side kick panel. I relocated mine to the glovebox when I wired it into the 25.
lilskyline240
are the wires for the consult normally wired through the white dash plug which sends info from the ecu to the consult plug by the fuse panel? Because when wiring my swap i wired in all the wires to the white dash plug. So im guessing i wont have to wire anything else up then?
wawazat8402
On that one, I couldnt tell you. Its been about 5 and a half years since I wired my car. All I remember is wiring the consult plug directly to the ecu, because the write-up didnt cover that.
lilskyline240
anybody else wanna chime in on this? Do i need to wire my consult plug directly to the ecu? or did i already wire it by doing the white dash plug wiring completely using all the wires?
eh?
Do you not have a little screw on the side of the ECU? It's recessed, and next to the hole (sorta oval shaped) the fault code light would be.
lilskyline240
nope no screw
mello88
Car: s13
2 RB25 has no screw or red LED on the back Found this out at the track on my buddy's S2.
bluefire wrote:Hook up the CEL wire. Then short the CHK and IGN ecu pins for 2 seconds and release. The CEL will now blink the code
That is amazingly awesome info, never read that before, thanks.. Does that just put it into diagnostic mode, then when you're thru short them again to clear codes & put it back to run mode?
eh?
Just curious, what color is your cas?The procedure for the pin jumping is in the FSM, pages EN-294-298. Doesn't see why you can't jump the pins directly at the ECU harness.
mello88
Car: s13
eh? wrote:Just curious, what color is your cas?The procedure for the pin jumping is in the FSM, pages EN-294-298. Doesn't see why you can't jump the pins directly at the ECU harness.
Never read the RB25 sections of the FSM, good info right there. My buddy's S2 has a black plastic CAS iirc, can't remember exactly but I don't think it's the metal one.
lilskyline240
mines an early s2 with a metal CAS not the plastic one
eh?
How come in a previous thread you say there is a screw on the ecu you can turn?zerothread?id=327223Do you have a different ecu now?Just curious, try to figure out how many ECU's the s2 RB25 came with.
lilskyline240
i totally forgot i didnt have a screw in this ECU. what happened what i bought what was supposed to be a S2 ecu from a guy and it turned out to be a S1 so i was still thinking of that ECu when i thought i had a screw
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
mello88: if the cas is plastic then the motor is the R34 rb25det. lev, solid lifters, gtr rods, and then some, if i recall.
eh: my S2 doesnt have a screw or light on it either. not sure if the consult was wired in correctly but i plan on checking on it soon.
lilskyline240
i wish i had my consult wired in but its not so i think ima have to wire one in so i can run my codes
eh?
silviasgp06 wrote:mello88: if the cas is plastic then the motor is the R34 rb25det. lev, solid lifters, gtr rods, and then some, if i recall.
The last S2 RB25's also had the black CAS. I think I have an early S2 ecu here, it has the screw but no light.
Bluefire
lilskyline240 wrote:i wish i had my consult wired in but its not so i think ima have to wire one in so i can run my codes
Dude its so easy to check codes. If you didn't wire in the consult plug don't even worry about it. Just find the "CHK" pin and "IGN" pin, take a piece of wire and connect them for two seconds with ignition on. If you did it correctly, you cel will flash any codes you might be throwing.
All nissans newer than 95-96 removed the LED for self-diagnostics. So you have to use the jumper method to manually check codes
-Bluefire
lilskyline240
dont i have to expose the wire to do that?
eh?
lilskyline240 wrote:dont i have to expose the wire to do that?
No just take a paper clip and jump the wires at the back of the ecu harness. Just take off the plastic cover.
lilskyline240
doesnt sound to hard to me. I just need to find a ECU pin diagram for the Rb25 S2 ecu. All i can find are S1's
Bluefire
those two pins are the same for S1 and S2
lilskyline240
alrighty thanks man. Does anyone have a wiring diagram of how to wire in the consult port by any chance? Im thinkin on buyin the Blizt datascan just because it seems like an awesome tool for checking out your engine
