Checking codes: LED doesn't flash?
Beau
I'm trying to check the codes on my SR20DET ECU and the red light is NOT flashing at all. I start with the screw completely COUNTER clockwise and then turn it all the way CLOCKwise and nothing happens, it just stays solid.
The car has been idling high ever since I installed it and running very rich. The ECU has a dent in the edge of the case from shipping that had me worried from the beginning.
Does a non-flashing ECU light mean that the ECU has been damaged?
solaris22
the ignition is on accessory right? If so check to make sure your doing the steps properly per the FSM
Beau
I was trying to do the test in ON mode. I just tried it in Accessory mode and nothing at all happens.
It is supposed to be done with the key in the ON position right?
Beau
I just read somewhere that the engine must be at operating temperature to get the codes. Is that true? A friend of mine with a CA18 said he got codes from his ECU when it was cold once. I know it's a different motor/computer, but it's still the same era Nissan.
Beau
Well, it was a bad ECU. I drove by Enjuku today and asked Ken if I could test the car with one of their ECU's and sure enough it worked. So I bought it and I'm going to hope the company I bought the first computer from will pay me back.
