elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Apr 05, 2004 4:58 pm
I would check your HVAC codes, if you can press a few buttons you can do this!!!
Turn the ignition on, and within a few seconds press and hold the OFF button, and keep pressing until all the lights on the display come on.
Then simply press the warmer button, and if you get a 20 (after a few seconds of it just staying at 2), then your good... if not post here... Press warmer again, and you should get a 30 (after a few seconds of staying at 3), then your golden. OTherwise post here...
Good to do the easiest stuff first, as it could be like a temp sensor (ive seen quite a few on here go bad)
