check this set-up out
mirra32
sorry and delete this if its a repost
some guy from another forum...on stock bottom end
A few weeks ago I posted up some pictures of my newest KA24DE-T setup running the SR ECU with a coil on plug setup. Last Thursday we dyno'd this newest setup at 20psi with these results:
442 whp / 409 wtq - Plot got deleted from dyno due to slipping clutch
433 whp / 409 wtq - Plot below.
Red-KAT
Car: 1995 240sx-se ka24det
I wish I knew how to wire up coils like that...
Interesting setup... Looks weard!
1WheelWonder
Car: 1991 Nissan 240sx
That's a pretty crazy setup.
lrb_2000
Car: '91 Nissan KA-T hatch
20psi on stock bottom end, crazy. .. so the distributor just kinda hangs out now?
Florida240sx
That's got to be B.S. What makes his pistons any different than the ones in our blocks? Ivan pushed the cars hard and at 400rwhp the pisotns ring landings gave away. This guy is pushing 450...and nothing? Altough does he have meth/water injection? If he doens't melt his pistons within 2 weeks I want to know why.... Well guess we will see how long it last. Pistons want to give at 400 andd fiz and a few other under 430rwhp have had the rods go bad. So let's see how long this thing last.
hysteria
Car: s13 kat, sv650s, and other projects
ugly but impressive.i can believe it. just because ivan only did that with one car doesn't mean he can't do better with a different one. sometimes you just get lucky. i don't know that ivan has tried to break his own record though... he seemed more interested in tuning the completely built setup and showcasing his products and results, which makes perfect sense to me.
haha i don't think anyone ever said it would last though. but we'll see i guess.
T4 RB25det
Car: 1995 240
pistons will melt when somthing is wrong. detonation, ping, knock, ect. a well tuned car wont do any of that and will run at the proper temprature. so there is no real reason why he cant push more than what people have done in the past on not properly tuned cars.
TheOne
Car: 93 240sx FB
or maybe its what ya call.....a factory freak, with good tunning:).
i mean there's ocasions when factory freak engines have withstand more than normal engines.
mirra32
here goes the video of the car....racing an ls1
http://silvia.rhombus-net.com/...1.wmv
MarkEmark
Car: fully-built '95 240sx KA-T
mirra32 wrote:here goes the video of the car....racing an ls1
Nice man, but you are asking for some serious trouble shifting at 7500 rpm with the stock valve train and stock rods. The stock rods can NOT handle that kind of power at that speed...
My rod blew a hole through my block at 16 psi and 3500 rpm. you've been warned.
Also, it sounds like someone's riding the clutch hardcore in that video...
mirra32
no its not my car...i found this post somewhere...and was freaken out when i saw the pic.....i wish somone knew more about this shietz...eric
MarkEmark
mirra32 wrote:no its not my car...i found this post somewhere...and was freaken out when i saw the pic.....i wish somone knew more about this shietz...eric
Duh, didn't read that my bad.
In any case, this dude's engine is not going to last long, at all.
Florida240sx
Wow guess aem ems wasn't good enough for IVAN's......
far1002
Car: cars art
curious how did he get the ecu to work
Nismo_Freak
Car: 89 Nissan 240SX
SR parts are just naturally superior, so of course it runs fine on stock block
IBsomeonemakesastupidarsecomment
Nismo_Freak
far1002 wrote:curious how did he get the ecu to work
Wire it in.
You could run about any 4-cyl. ECU in your car if you try hard enough.
Hell I bet you could make a Honda P28 ECU work and convert over to MAP, you'd have to get Hondata to retrim the maps.
