Check this out...
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
I guess this what happens when you hear noise coming from the front of the engine. I first heard this noise when it I turned off the car and it was making this grinding noise (yes car off) lol. Then it started to heat up and make louder noise. Finally took it off and inspected it. And them are the results.
240z4u
Car: '95 Nissan 240SX
Were you running the cas installed with no front cover??
Damn dude, is it damaged?
Evan
uber95
Car: S14
Whatever you do, DON'T SNORT IT!! what do you attribute that to? Is it possible that the CAS created it? Or is it from????
nizmo zilvia
240z4u wrote:Were you running the cas installed with no front cover??
Evan
Correct. Why wouldn't it be damaged? No wonder I couldn't set the timing if it depended on my life
uber95 wrote:Whatever you do, DON'T SNORT IT!! what do you attribute that to? Is it possible that the CAS created it? Or is it from????
LOL!!! I'll try not to
Yes it from the CAS. We took it apart and we saw some small pieces of metal come from under the sensor itself (that black round thing). So yea its from there.
S13 240SX
Car: 93 Mazda Miata
that sucks.. that happend to me once.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Thats nothing to worry about, it's just magical RB fairy dust. It gives RB's 400hp to the wheels.
S13 240SX
Car: 93 Mazda Miata
Evan
i would think so.
that happens the disc is burnt you can tell from his photos that u can see that the disc is burnt..
I wouldn't say its damaged i'll say its toasted.
nizmo zilvia
Yea but since this happened its no good obviously. Right? I would think so. Anyways I have a new CAS headed my way so I'll see.
Do you guys think this is the reason why my car bogs and bogs, backfires, and finally dies after idling for 3 mins or so?
nizmo zilvia
Yellow4g63 wrote:Thats nothing to worry about, it's just magical RB fairy dust. It gives RB's 400hp to the wheels.
Guess I have no more fairy dust because it got all taken out.
Shocker
Car: 89 240sxHB rb26/30
was that **** inside the CAS?
nizmo zilvia
Yes it was lol.
Question...
I try to crank the car and it doesn't turn over. I have 2 batteries starting the car so I know its got enough juice. Whenever I crank WHY does air come out of my intake (connected to turbo like stock) making noise like poof poof every time the motor turns over. Any ideas?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
had a machine shop set up one of our EVO6 4G63 wrong, did the same thing, ended up the intake valves weren't seating correctly.
Not to say thats your problem but was doing the same thing
nizmo zilvia
Ouch... Hopefully this isn't the case cause it doesn't always do it.
DeclareYrWar
could possibly have something to do with your timing
nizmo zilvia
I hope it does, haha. Right now I don't think there is any timing so every things outta order. We'll see with the new CAS. Thanks again Declare.
MEclipseGSX2G
FTW that was my hand lol, also I hope the new cas will fix everything. and gonna fix up some wiring that causing some light go flickering oh well we'll see whats goin on soon
nizmo zilvia
That reminds me. Interior lights flickering all of a sudden means bad ground right?
DriftX
Car: '89 240sx
Haha peter I told you it was a cas problem.
Now I guess you know why the car was running like ***.
