Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Sun Jan 29, 2006 4:38 pm
Even if you can start your car, your steering wheel lock will prevent you from turnning... Anyhoo, here's what you need to do.
On your steering column, take off the black trim that is housing your key hole. Behind the key assembly is a white plastic box with about 5 or so large wires going into it. Unscrew it with a regular phillips screw driver. Once that's off, pull it out and stick a flat head screw driver in the little groove. Turn clockwise to start.
