Check this DIY engine sling
Drake57
Car: 1992 Q45, 1990 Q45 (parts), 06 Sportster XLC, 85 XJ6, 08 4Runner, 89 Suburban 4WD, 75 Honda CT90
I put together when I needed to drop the pan:
http://www.q45.org/gallery2/v/....html http://www.q45.org/gallery2/v/....html
It's 3" drill stem left over from framing my boat shed, 5/8" threaded rod bent into a J bolt for the passenger lifting loop, 1/2" threaded rod to tighten the chain loop for the driver side - I welded a steel carabiner to a piece of 1/8" plate for the driver side lift point.
The two pieces of drill stem are not welded together - I cut a saddle notch out of the piece that runs fore/aft, and notched the top 4X4 slightly. The pieces stow more compactly than if they were welded together.
It served well, made from scrap for the most part, did not take too long to build.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Ouch! That's a lot of weight on those fenders!
Give me a call next time and we'll get my engine hoist up there and see if it will work on a VH45DE. I don't have the special attachements exhibited in Tangalora's excellent post.
thejapino
Car: '93 J30t
Oh, I thought you meant DIY like this.
TBrack
Car: none
LMAO
Drake57
Brian, thanks for the offer. I have an engine lift, but it has feet that would be under the car, in the way of dropping cross member and pan. I got the inspiration for my design from one of the slings shown in Tang's epic thread.
I've since reinstalled the hood, and suffered no damage of any sort due to sling, so I feel that it is well suited to the task, requiring much less strain than the method shown above.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Good deal. Without an overhead crane type device, you will have to deal with the foot issue.
