turbo2nr »
https://forums.nicoclub.com/turbo2nr-u33029.html
Tue Nov 11, 2008 3:28 pm
basically on the ignition map where you start hitting boost subtract .75degrees timing per ever psi as rpm increases. that should be safe, then after once your on the dyno you can take away timing (advance it) until you hit peak torque)
as for the fuel the formula is Formula = stock 270cc divided by new injector (ex nismo 555cc) = 0.66cc x 100 = 48.6%.
so you need to subtract 48% fuel for car to idel and perform close to stock.
form there just keep making the percentage less to increase fuel therefor increasing a/f mixture making it more rich, you would want to do this on boost.
be careful and take your time!
baby steps dont make drastic changes, dont push on the car make a change and see how the car reacts before making more changes..
