Krew126 »
https://forums.nicoclub.com/krew126-u140567.html
Tue Dec 08, 2009 7:15 am
Well I was bored so I went outside and took a picture of mine for reference:
Here I'll just make an example scenario for adjusting the height. Lets say you wanted to lower it more, what you would do is take the spanner wrench if you have them, and break lowest collar loose. Then you would spin that collar up some (to get it out of the way), and then you would spin the actual strut assembly piece and turn it up to go higher. But that is to lower your car.
To raise it, you just do the opposite. You spin the strut assembly so it goes down. Although in your pictures I don't see the collar to lock in the ride height. So all you should have to do is loosen the strut tower bolts, then unbolt the two on bottom, and spin that piece down. It's as simple as that.Hope this helped.
