xyster »
https://forums.nicoclub.com/xyster-u1869.html
Wed Aug 13, 2003 9:39 pm
$2000 will get you a decent suspension setup with LSD...but that's about it. It won't get a motor swapped in, not even a CA, certainly not an SR or RB. You should tune it up first; make sure all the maintenance is up to date. Then I'd get a decent spring/shock combo i.e. sportlines on kyb agx, swaybars, strut bars, bushings, vlsd, some decent tires, and maybe intake/exhaust. If you shop around, buy used stuff when possible, and do all the work yourself, you might be able to just barely get that in under $2k. That'll give you a car that's tuned up, handles very well, is a tiny bit faster than a stock 240 and sounds good (since you seem to be interested in the cosmetic side of modifying cars).
