You could use the same bolts that are on your current diff cover.Most hardware stores should have the 14mm x 1.25 thread bolts you need. Just make sure they are GRADE 8.8 or higher (12.2 preferable).
JDM is the true path to performance!
[email protected]'89 NISSAN 240SX, '90 KA24E SOHC,5-spd conversion,'96 180sx turbo fuel pump,port & polished these:12v head (in/exh), MAF sensor (main inlet only), air filter adapter, throttle body, intake plenum, intake manifold, removed SCV valves (2nd butterflies) Injen intake, HKS SuperMega Flow Filter, HotShot Headers (w/ thermotec exh. wrap to cat-back exh. canister), custom 60mm straight exhaust (JDM), HKS Superlow Form Springs, KYB AGX shocks (adj.4/8), FR/RR strut bars, Nismo Chassis brace, Random Tech High Flow cat., custom 2.5" JDM style exhaust,HyperGround Wire System, Magnecor 8.5mm wires, Splitfire 3xPlatinum plugs, Nismo Radiator Cap (18psi/1.3bar), S13 VLSD, ENDLESS brake pads, Jun Lightweight Flywheel, Centerforce Dual Friction clutch,Optima Battery, Bomex body kit, about to be the 1st, FIRST! in the US with a JDM Ikeya Formula Complete body kit...
