Check out my 1993 Chain guides, i'm shocked!
dareo
Car: 1993 Q45, 1989 240sx
Okay i spent $380 ordering the chainguide kit from Joe, and take off the front cover tonight. The guides are already fully metal backed. The sealant is a light blue around the cover. The guides also look slightly different than the ones i bought from joe.
Attaching a much smaller pic of my guides, as they came from the factory.
This car has 128k miles, has had dealership oil changes for the first 100k, and the guy i bought it from had a lot of stuff done at the dealer as well. But there is no dealer record of the chainguides. My production date is 10/92, VIN JNKG01C2AM224026.
So...is this further proof that 'some' 93s come with the updated guides?
Also, the oil pump chain seems to have a good deal of slack and the sproket just spins freely on the crankshaft. Whats up with that?On the left chain slack side there seems to be some slack there as well, not quite enough to really worry me but there is slack there. The other chains are tense.
The original problem with my car, that prompted me to do the chainguides, was a strange rotational rattling kind of noise. Sounded just like i had a piece of a guide rubbing the chain but thats clearly not the case. This engine doesn't burn or leak a drop of oil, gets good mpg and emissions. But it had a funny noise so i figured i had to do the guides.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Well you can get your money back, and you tried to do right by your baby too !
The oil pump sprocket is held in place by tension from the big bolt through the balancer. Makes you want to stand on a ten foot bar to snug it up doesn't it?
Yes, seriously.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Wow, you're lucky and I bet you're happy!
However, whats up with the guide bolt I have circled in yellow? Is it stripped, or is it just discolored, or???
dareo
For reals the oil pump sprocket is only held in by the crank bolt? thats makes me nervous. It pleases me to see how clean the engine is under the cover, its a very light golden color. This one was oil changed for sure.
dareo
that is just a discoloration, and an effect of trying to get the pic small enough to post up.
dareo
I've decided to sell the kit here for $300 shipped, to avoid having to RMA to Everythinginfiniti and pay restocking. zerothread?id=117081 is my thread in the infiniti parts section. Great deal for someone who actually needs the parts.
Have the dealer retorque the bolt on the crank pulley just to be on the safe side. Its nice to see people are taking on chain guides as a DIY and saving these gems!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
dareo wrote:The guides are already fully metal backed. The sealant is a light blue around the cover. The guides also look slightly different than the ones i bought from joe.
Now you can rev to the redline without worry.
Joe will take them back if unopened without restocking fee, you pay shipping back.
PalmerWMD
Car: 2004 350Z
Dareo:whats your cars production date?
Fred..
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
dareo wrote: My production date is 10/92, VIN JNKG01C2AM224026.
PalmerWMD
Car: 2004 350Z
since 93 was a short production year this was a bit more than halfway thru production.
Fred..
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
But we still don't know if the guides were factory or dealer installed for certain.
gniknave
maxnix wrote:But we still don't know if the guides were factory or dealer installed for certain.
The metal on those guides almost looks too clean to be factory installed. When did you get your car dareo?
dareo wrote:For reals the oil pump sprocket is only held in by the crank bolt? thats makes me nervous. It pleases me to see how clean the engine is under the cover, its a very light golden color. This one was oil changed for sure.
True it is, but no need to be nervous. As long as it's torqued to no less than 270ft lbs. then you'll be ok. I remember Jesda telling me that he had a problem with his oil pressure (?) because the crank pulley (aka harmonic balancer) wasn't torqued to 270ft lbs. So that's the importance of it.
PalmerWMD
Car: 2004 350Z
I also wish to remark how clean your engine looks under front cover.This means the rest of your engine is likely clean as well.
Fred..
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I was going to comment on that as well Fred!
It looks really clean in there...
More proof that some 93s get the good guides, but dont let this not verify..
Q451990
Very clean engine... looks as good as mine at 47K when we replaced my guides. I think I would go ahead and replace the oil pump chain... they are known for stretching. Might as well replace the tensioners too...
What color was the RTV on the front cover? I suspect that those guides were from the factory if you don't see mention of them in the dealer service records. You would have probably heard about guides if someone actually paid to have them replaced...
Heath
DAEDALUS
dareo wrote:The sealant is a light blue around the cover.
dareo
The lighting of the picture really doesnt due the cleanliness justice either. And i never used any flushing products, just switched it to 0w40 mobil 1 when i bought it.
PalmerWMD
Car: 2004 350Z
dareo wrote:The lighting of the picture really doesnt due the cleanliness justice either. And i never used any flushing products, just switched it to 0w40 mobil 1 when i bought it.
One of the Top 3 off-the-shelf oils on the market foir this application.
dareo
RTV was light blue. This car has an extensive dealership service record. I don't think anything was done outside the dealer untill the guy i bought it from got it at about 100k. And he didn't do the guides, he said it was probably new enough to not need them. I've had the car since 120k, or about 8 months.
