check engine Weird a** code p194
womanizer
Hey guys my engine check light went on >=[ and the code I got was p194 does anyone know what it means? I tried searching on google(and here) and didnt run into any codes like that...plz help if anyone knows! I have a smog test in 10 days! The guy I bought the s14 told me the code and he said that he was told it was the cat, can anyone confirm that is the code for the cat? Any reply will be greatly appreciated!!
kaytech83204
Car: car
that would be a fuel rail pressure sensor failure code:( when you google codes all nissan obdII codes start P0xxx i.e. P0194= fuel pressure. should be easy fix, a friend threw one and ended up $4 injector seal fix
womanizer
Thanks! How do I fix it? btw all those mulitpal threads were created on accident, I am sorry how do I delete them? my pc seems to be double clicking and loads slow ,acting up hella bad.
kaytech83204
Car: car
mmm. you can take and turn your key on to the point where your fuel pump primes for a few seconds.. do that a few times without starting it.. than pop your spark plugs out and see if you have excess fuel on any of the plugs.. if you do then simply replace that injector seal set.. if none of them do you may have to hook up a fuel pressure checker and go from there.. I'd consult a shop for that though, pressure checkers aren't cheap.. good luck
womanizer
Thanks for the help! I went on ahead and got it fixed!
