CHECK ENGINE
nabm37x
Car: infiniti m37x 2011
hey guys,
I hope someone could help me there.
i have a check engine that always comes up and the code error says very small leak detected... is it on my muffler?? is it findable (since its a very small leak) or I should change the whole muffler line
thanks
Ilya
What is the code? And how long has it been happening? How many miles on the car?
nabm37x
the code is P0456, its been happening for a year now and the car is at 132 000 KM
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
nabm37x wrote:
Mon Nov 11, 2019 10:43 pm
Nothing to do with the muffler - it's related to your EVAP system. You have a small breach in the vacuum lines from your fuel tank to the charcoal canister to your intake. Purge valve and/or canister vent valve could be bad, canister could have a crack, gas cap could be faulty or loose, fuel tank could be leaking, or a cracked hose. The code is thrown when the EVAP system performs a leak test by closing the normally open valves to check vacuum. It doesn't take much of a hole or crack to set the DTC.
Also, when you fill up make sure you don't "top off" by repeatedly squeezing the gas nozzle. Excess fuel can get into the vapor lines and cause problems with your control valves. When the nozzle clicks the first time - stop filling up.
Malbec 56 Beast
Car: 2013 Infiniti M66xS Totaled 4/11/20
What's next???
2010 Subaru Legacy
1983 Porsche 928 S Euro (Sold) 2/17/20
I'm one of those guys that tops off the tank, I am guessing I should stop doing that.
Shiz
Ilya
Malbec 56 Beast wrote:
Tue Nov 12, 2019 12:15 pm
Shiz
I did it for a while and then stopped for a few years and recently catch myself doing it again. Will need to be better lol.
