Hello. I just had the same problem. I got my cat back put on and 2 weeks later the check engine light went on. (Do you see something in common...) Go to
http://www.240sx.org, Find the "FAQ" on the top of the page. Scroll down on the right hand side and find "ECM, finding trouble codes for DOHC" (I am pretty shure you have a DOHC and not a SOHC). Follow the instruction on how to take the ECU out and test it. (DO NOT DISCONNECT THE ECU!!!) I tested mine and I could not find the RED LED. However, when I followed the instrutions, I found that my check engine light would flash on and off instead of that red led (so use the dash light....) If it is the rear 02, it should flash 7 times slowly, than 7 times fast (which means 77). The consensis is that the Rear 02 is useless. So do not get it changed (according to Nissa...)Hope that helps.As for your cataletic converter, make shure the guy knows what he is talking about. I am not shure if the Canadian cars are the same as the American cars because my cat. is beside the manifold. If you are talking about that round thing with a flange on it that is bumpy, it might be a "Sub muffler" and not a cat. Go to Nissan and have them take out the sheet with the underneath of your car. Most mecanics make that mistake and think this part is really a cat.............so you might not have a "true" cat-back.....but thats okay. Nobody know but us Nissan guys.If I got anything wrong, I have only been in this for one year. So anyone can correct me....
Paul1997 240SX
