check engine!!!!!!
Wanta240sx
Car: none
I was driving today, and my check engine light turned on... can anyone help me out on why it did that?? and what i can do to solve the probllem help asap..
Wanta240sx
Car: none
its a 91 240 manual
boke_as_hell
Car: 92 240sx hatch
have someone run a diagnostics scan. I know most dealer ships do it and auto parts stoors
Wanta240sx
Car: none
i heard we can do our own.. anyone kno how to?
351cka24de
Car: 1995 240sx
i don't know if it is the same in an s13, but i have an s14 and i can check my CEL using the following: on the passenger side kick panel, there is the ECU. on the ecu is a screw looking thing. you need to turn the screw and then turn the key to the on position. or visa versa, turn to on and then turn the screw. the check engine light and a little red LED will blink out your error codes. if you can get this far, you need to look up a field manual or chilton's to get the exact codes.
hope this helps... my first post at nico
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
I would type it out but it would take forever so go to this link:
http://www.240sx.org/faq/index.html
Kyo Kusanagi
Car: 1995 240SX SE
let me know what the code is when you get it. I'm just curious on what made your car engine light turn on.
