hitesh9 »
https://forums.nicoclub.com/hitesh9-u35501.html
Sat Feb 02, 2013 12:08 pm
Hi all, I have a 2001 Inf I30, 100K miles, which has recently got the Check Engine Soon light - codes found were P1320 and P0464. Car is running fine and I do not find any roughness in drive. P1320 relates to Ignition Signal Primary and P0464 relates to Fuel Sensor. There are numerous posts here for P1320 and most indicate problem with one or more Ignition coils. I have checked each of the 6 ignition coils as well as the condenser based on directions from a seasoned member's detailed posting here and steps in FSM EC, for battery voltage, resistance, continuity. All 6 coils and the condenser are fine based on those checks. Any clues what else could be wrong here ?. Any further insight into this problem will be very helpful. Is problem with fuel sensor (P0464) connected with ignition signal (P1320) ?. A few years back, I changed the front 3 spark plugs, but could not reach the rear 3 and thus rear ones have never ever been replaced. Car starts quite well even in the coldest mornings (3 below), and runs ok too so I'm ruling out the spark plug issue. Thanks for reading thru and sharing your thoughts.
