Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Mon Dec 10, 2007 6:26 pm
Ok, for those of you with non California vehicles, you can wire up your check engine light pretty easily :-)
All you need to do, is pull your gauge cluster, and put lights in the 2 empty spots...
next, where the ECU is, there is that white connector that has the blue/black wire and so on for temp gauge and all..
There is a red wire.. ill get the pin later... if you put power to that, the check engine light comes on :-)
So, following this fact, I am wondering if pin 32 (monitor and check lamp (red)) is the check engine light on the rb20det ecu.. if so, connecting the 2 wires should work - right?
