mikew83 wrote:Larz wrote:Timing chain??? I thought the advantage of a chain over a belt is that the chain lasts the life of the engine unless it's oil starved. Am I wrong?
Larz, I can tell you from my I35 and other Nissan vehicles, it's not so much the chain, as the fact Nissan uses PLASTIC for the chain-guide. My I had the most annoying knocking sound, from the metal chain hitting the plastic. Grade F engineering, if you ask me. Mixed-material components are a big factor in premature failures of parts that shouldn't for years, but will.
Do you have any idea how noisy a metal chain would be rubbing on a metal guide? Of course the upper portion of the guide is plastic, it drastically reduces noise and chain wear. The lower portion that bolts to the block is metal. Occasionally, I see those codes on cars that haven't been maintained well. The easiest thing to do is the exhaust timing relearn, and if that doesn't work, you possibly have an exhaust sprocket stuck. When monitoring their position, one generally reads 5 degrees, and the other is stuck at 14 degrees retarded. You can pull the VTC cover off and loosen the sprocket bolt and watch it snap back into position, then retorque the bolt. Keep up with oil changes, even sooner than recommended for a while to keep sludge from clogging the actuators, as they rely on oil pressure to advance and retard timing. 95% sure one of your sprockets is stuck, but be thankful it's not a QX56 that stretches the bank 2 chain and nearly rubs a hole through the oil sprayer. I just finished this truck yesterday. You can see the passenger side chain is so stretched its nearly rubbing on itself. The tensioner was maxed out. The oil change history on this truck was sketchy, she changed it roughly every 10k. On a direct injected motor, that's no Bueno.
