BCQ wrote:It is a 1994 with only a little over 54,000 on the ticker it does not get driven much since I work out of the home.
Wow... great car! You may have the lowest mileage G50 in the board now! I'm approaching 70K on Q2.
1994 was still OBDI so whatever the code is, it's pretty major. OBDII cars "check engine light" you to death - even to the extent of coming on for a loose gas cap. The OBDI system wasn't that sophisticated, so when you see that light, it's typically something that needs to be fixed.
The good news is that you're close to T3 in Atlanta!
Heath
