Humble_One »
https://forums.nicoclub.com/humble-one-u11185.html
Tue Apr 06, 2004 4:39 pm
Thought I'd post a follow-up...Driver's side tube was charcoaled for ~2 inches from the intake. A small awl, a can of berryman's, and about two hrs labor is all it took. No $800 to the stealership, no $300 to Joe Blow...this one is a slam dunk.Anyone with code 32 and what seems to be a working EGR would be well served to take on this task. FWIW, watch the valve cover bolt at the rear brackets (don't over-torque as I did on the DS) and the coolant intake to the EGR has to come off, even if you leave the valve in place (its in the way).
