qship96 wrote:Update to problem at hand.....first off a big thanks to Mike {goody 90q45} for sending me one of his spare solenoids, unfortunately I can now answer why Infiniti lists 2 different part numbers for the part{ mitsubishi and hitachi} the connectors are different, close- but no match.....how stupid of a design is that??????
I am going to see my buddy Frank Hill tomorrow to have him replace the swaybar end links and bushings, and will see if he has a spare connector plug that I can match up to the solenoid and then solder into my current harness after cutting the original connector off......if not, I will have to bite the bullet and waste $90 on ordering the part from IOS, and return Mikes part to him......things are never simple when dealing with an old beast, especially when it is 105F out!
Well, spare connector in hand!!!! frank had a box of various Nissan connectors and pigtails salvaged from previous jobs....will splice and test on Saturday when it is cooler outside. A fyi, had front swaybar endlinks and bushings replaced- bushings were toast, but shockingly the 255K old drivers side end link was still in good condition.....replaced the pair anyways as I had already purchased the pair with bushings{ only $41 from Amazon}
