tigerclaws1318 »
https://forums.nicoclub.com/tigerclaws1318-u117680.html
Sat Mar 21, 2009 2:32 pm
This afternoon when I went to start the car I noticed the check engine light on. I was thinking thats kinda strange what couldve been wrong. So I went to autozone and scanned the code and it came out to be U1010. I tried looking this code up but no luck on details. What I did find was a tsb on it.
This bulletin has been amended as of 3/30/06. The Applied Vehicles, IF YOU CONFIRM and Claims Information sections have been changed. No other content has been changed. Discard all previous versions of this bulletin. IF YOU CONFIRM The MIL is "ON"with DTC U1000 or U1010 (CAN COMM CIRCUIT) stored in the engine control unit, and there are no drivability incidents, DETERMINE IF This bulletin applies by performing steps 1 and 2 of the Service Procedure. ACTIONS If this bulletin applies, ther e may be excess resistance in certain ground connections: Clean/re-tighten ECM ground connections. Clean/re-tighten negative battery cable body connection and battery post connection. If needed, clean and ensure good contact between the steering member assembly and the left side instrument stay assembly. See this bulletin for further detail.
Anyone else has had this issue?
