Check Engine Light
atiffarooqi
Car: 2003 Nissan Sentra SE-R Spec-V
Hey guys, my dad has a 2001 Maxima GLE and the check engine light has been on for a while. The car runs perfectly normally. im guessing its one of the sensors. Is there anything i can look at before sending it to a mechanic?
And while im here, i wanted to know if the GLE 2001 is powered by chain or belt.
Modified by atiffarooqi at 11:32 AM 5/19/2006
maxhopper
Car: 02 Maxima SE 6spd
If you take it to Autozone, they can check the code for free. Then you can check this thread to see what it means. zerothread?id=126537
Yes it (and all VQ's) has a timing chain.
atiffarooqi
Wow, that helped big time. thanks a lot.
atiffarooqi
So it turns out that O2 sensor 2 in bank 1 is inactive, and if im not mistaken, this is on the driver side after the 2nd cat. Is it possible to replace this myself? The Sensor is about $110
maxhopper
Totally a DIY job. You'll need some penetrating oil (PB Blaster) and a 21mm (I'm pretty sure) wrench or O2 socket tool.
atiffarooqi
So, where are all of the )2 sensors located? Do you know of anywhere with a better price?
autotech43
What trouble code was stored? That particular year model may or may not require the ECM (electronic control module) to be reprogrammed.
