Check Engine light stay on?
RS91
How concern should I be? The car is running fine with it.
91nis240
yes you should be concerned, especially b/c your car is stock. i say b/c some times when you put an intake or some kind of mod, it will throw a code, all you then do is reset the check light and your fine. But since you have no mods done , there is a problem, could be small, could be large. get it checked out.
Queamore
Car: Cars.
Yeah go get it check out. It'll save you alot of frustration in the future. Belive me I'm saying this from experience.
lunchmeat5000
My car did the same. The front O2 sensor went out, but it still ran fine. Luckily, i worked at a nissan dealership, so i "borrowed" a diagnostic machine. Took about 20 mins to fix.1997 240sx se
Redfastbk
Car: my 240
1990 240sx hatch, my engine light comes on once i stay at a constant speed. usually on the freeway at about 65-75 mph constant speed, but if i accelerate or decellerate, it will turn off, but as soon i hit constant speed it turns back on. i have a K&N cone air filter and headers if that helpes in determining what is up with my engine light. any response will be appreciated
RS91
How do you reset the check engine light?
Jaegermeister2k
RS91 wrote:How do you reset the check engine light?
Check this out.
http://www.240sx.org/faq/articles/ecm_reset.htm
That's from the 240sx faq's page
I tried it but after i started the car up the SECOND time after resetting the light came back on.The power is still there though(Unlike i thought at first).
