Check engine light. Questions
EriCCirE
Car: 1993 Infiniti J30
Hey guys,
When driving my check engine light sometimes comes on and stays on for about 10 minutes. I have no clue whats wrong, I was thinking the o2 sensors but i was hoping to get someone elses opinion.
Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
youll want to check your ECU codes
yodawill2000
Car: 94 Infiniti J30
thats whay mine did when the egr pipes were clogged .ECU showed EGR Function error
driverdriver
Car: NICO's longtime resident Canuck!!!
Its best to get the codes, since the CEL could be set off by any number of things. If you don't have a scanner, go to a Pep Boys or an Autozone store, they can pull the codes for free.
yodawill2000
Now you tell me !!! lolI yanked the ecu out and read the error light sequence ..I didnt know they could check the odb1 stuff.
elwesso
2007 BMW M Coupe
yodawill2000 wrote:Now you tell me !!! lolI yanked the ecu out and read the error light sequence ..I didnt know they could check the odb1 stuff.
They cant. they only have OBDII connectors..... at least hte ones around me havent been able to.. Every OBDI MFG has a different connector (nissan consult, GM TechII, etc)
