Check engine light problem SEARCHED! WTF?
TougeSlide
Car: Sr powered 240sx
the car: '93 240sx hatchmotor: sr20det redtop Error code: 55the problem:
This morning while getting on the interstate, my check engine light came on. I just finished putting on SS turbo lines, and an s15 exhaust manifold gasket. The car was laid up for a while waiting on parts. It ran great sat. and sun. I have never checked ecu codes before, but I did this morning after driving back home, the ecu threw code 55. The car ran fine and I read on here that 55 is this "everything's ok, but there is a problem somewhere" code, so I drove to work. On my way to work the light turned on and off again twice. It went off while driving straight, came on while turning right, went off again later while turning left, and came back on when going straight.
I am baffled.
Anyone have any ideas?
BoostedNismoNJ
Car: 1991 240sx
Did you check all your fluids???
TougeSlide
yes, all fluid levels are at the right level... accept maybe windshield washer fluid, but that wouldn't set off the check engine light would it? i had mine off for a long time but just put it back on. i thought about it but didn't think that would cause the CEL to come on.
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's probably a loose connector somewhere if it's only doing it under a turn. Double check all of your EFI connections.
It could also be that the ECU has an old code in storage and just needs resetting.
TougeSlide
it is on while driving straight, and goes off when i turn. i thought it might me a loose connector. ill check them all when i get home, and try resetting the ecu. i had to disconnect a few things when doing the SS line install so i will check those. the only things i can remember disconnecting were my o2 sensor, and the oil pressure sensor (i had to take it out to check fitting on my oil pressure gauge and i was going to install buy haven't yet. no one in town had a BSPT to NPT thread adapter. Headaches)
Goldeneagle
Car: 1992 240sx Coupe
When was the last time you replaced the O2 sensor?
The check engine light, usually, starts to act up when the O2 sensor are about to go out.
Your best bet is to be ready to pull the code the next time the computer throws a code, regardless of where you may be.
James@CI
Car: 89 Nissan 240sx with SR20DET
Reading through everything you said the one thing I was thinking the whole time while reading.Check your oil pressure sensor that is what I would go after.
TougeSlide
I checked all the plugs this morning, they all seemed to be properly connected, but I'm thinking it might still be a connection somewhere because when I go around round-abouts, the CEL turns off.
Also, isn't the oil pressure sensor just a switch? I.E., if it were badly connected, nothing would happen, or if it were disconnected entirely, nothing would happen. I could be way wrong, but I thought all the oil pressure sensor did was turn on the idiot light if pressure dropped below 8 lbs.
BoostedNismoNJ
Car: 1991 240sx
What about the HICAS???
TougeSlide
BoostedNismoNJ wrote:What about the HICAS???
no HICAS.
BoostedNismoNJ
Car: 1991 240sx
Did you eliminate it?
Or was it never on your car?
TougeSlide
no i never had it, sorry, should have been more clear.
jetroy240
Car: S13, AE86
try to get the code after driving (when the CEL came on & off) but don't turn off the ignition while retrieving the code. Sound like the ecu battery saver was tap to an ignition signal, that's why evrytime u turn off ignition, the code was erase, if it's ok, possible ecu problem, try to borrow another ecu to check it.
Modified by jetroy240 at 6:26 PM 1/19/2008
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
maf in need of cleaning?
TougeSlide
ill give that a shot, too.
TougeSlide
ok, i cleaned the maf, and re checked all the plugs and connections. The CEL is still on and i still have code 55. the light is on all the time, EXCEPT sometimes when go around round abouts (thats turning left for extended periods of time). i have checked for a short some where but havnt found one.
anyone else? someone please help, im not a noob at this so im really frustrated lol. ive checked and re checked everything that makes sence to me. Ive had the manifold off several times and never had a problem.
BoostedNismoNJ
Car: 1991 240sx
Try turning the wheel while parked and see if the CEL comes one
TougeSlide
The CEL is on while parked and not doing anything. it goes OUT when i go around round abouts.
